I just bought a Dell Inspiron 2200 with WinXP Home. This is the first time I have to deal with XP in any depth and I find it *extremely* aggravating that it tries to keep you from configuring things the way you want them and tries to force you to like it the way they want you to like it.
It comes with a program called Dell Jukebox player which I *hate*. Well, after spending quite some time configuring my audio file associations, I must have clicked on some file or something which launched the stupid Jukebox and it hijacked all the associations back to itself. There must be a special place in hell for guys who write software that does this type of thing. I intend to write Dell and complain but, anyway, that problem has been solved by just deleting the program. Nevertheless I still have a number of issues which are frustrating me.
Windows Media Player 10. I hate this program with passion and it also tries to hijack everything in sight. But hey, try to delete it or change the file name and windows just creates another copy out of thin air. You *cannot* get rid of it because MS say you *must* like it and you *will* like it. Some files or events will trigger it and then you have to close it down before it hijacks your computer to hell. Can someone help me disabling this? How can I get around the "feature" which replaces it if it is deleted?
Optical drive auto insert startup. This is another thing I *hate*. In WIN9X you just checked a box to disable the auto run "feature" and it would leave you alone but not in XP. No sir. You really don't want to run that disk? No. But what if it has pictures of your children? NO. And what if it has music by the Crappy Redmond Syphilitic Brass band? NOOOOOOO! Arghhhh! Twenty times I say NO. No means NO! and yet I can't get it to not start when I have a DVD in the drive which means that I have to keep the drive empty or it will autostart when I startup the computer. Is there any way to disable the autostartup "feature" for once and for all? (I mean short of jamming a screwdriver into the bay, which I am quite tempted to do.)
MSN Messenger. If you get married you can get a divorce but once you use MSN Messenger it will take over your computer and you will never get rid of it again. It will start up automatically when you start up the computer. . . or when you start Outlook Express. . . or when you sneeze a little too loud. I absofuckinglutely hate this program. Unfortunately I am forced to use it ocassionally because I need to contact some people who do not have ICQ as I do so I have no choice. How can I get it to just go away and stay away when I close it down after I use it?
One more thing: In past threads I have had posters telling me I should just learn to like things the way they are and suggesting there is something inherently wrong with me if I think I know better than Bill Gates. If you are thinking of posting along those lines I would ask you to not do it. If you do, it's not going to be pretty. Don't say I didn't warn you.
