I've been put in charge of bettering the conference room's video conferencing capabilities. I guess right now they are complaining about poor performance from one of the apple iSights (http://www.apple.com/isight/). It doesn't seem to pick up everyones voice in the room.
I was thinking they should just get something like this:
http://www.audio-technica.com/cms/wired_mics/3e0e3e5cec6fe424/index.html
An omnidirectional microphone--Audio Technica being a reputable audio equipment seller. The only problem is that they would like the interface to be usb so this microphone audio would have to be converted so it can be plugged into an Apple PowerBook (15 inch).
Another solution to this problem that I was considering is to put multiple microphones in the room and send them to a mixer that has usb out. Something like this:
http://www.zzounds.com/item--ALEMULTIMIX8USB
Also would it be better to just use the audio line-in to send any microphone input instead of using usb?
Any suggestions?
Summary:
I need something that can either take 8 or so mic inputs mix them and send them to a PowerBook. Or a really good omnidirectional microphone or 2.
USB or line-in.
Any suggestions?
Summary:
USB or line-in.
