ninethreeeleven
TKer
- Jul 16, 2004
Okay my parents house (where I live at the moment) is pretty large. The main computer is in the back room and my room is at least 75 feet away (shortest point) but there is a bathroom and a chimney in the way. Here is a quick sketch of the first floor layout (second floor is pretty similar, only differences are in the top right corner and dont matter)
Do you think I will have trouble with interference here, or should I save the money and just get a router and cables (I can run under the floor to my room, computer 2) I can then go up to the room which will hold computer 3. It wouldn't be that hard to do this (not to mention a crap load cheaper) but my father is interested in getting a wireless router.
I wont be living here in a few months and then will have a wireless card that I wont be using.
Any ideas and advice would be greatly appreciated.
Also if you want any more info I'll get it.
And if you think I should go wired can you recommend good router and wiring (or is it all the same)
-9311.... knows nill about networking.
EDIT: changed pic
EDIT: changed pic
