Concern! On My New Build?
exilelrrp
Case : SS FT02/B-Window-------------------------------------Received!
MoBo : Gigabyte GA-890FXA UD-7-------------------------Received!<---Concern! Will it fit my FT02:eek:
CPU : AMD Phenom II X6 1090T------------------------------Received!
Mem : ???------Corsair Dominator 8GB 1600 (PC3 12800) Heat Spreader Blue------???...Do i have to O.C ???...to use 1600
Video : EVGA GeForce GTX 480 1.5GB------------------------Waiting
PSU : Corsair HX1000W---------------------------------------Received!
Please help! on this Mobo before i return i back!...Goin' for the black & blue theme
The mobo should fit fine, it's just a normal sized atx board.
...Really???...Why would they put ( Extended ATX Mobo )???...Dimensions On the Mobo 12.8" x 9.6" & on the SSFT02 Maximun MoBo is (maximum 12” x 11”) ???...Now being that the Mobo is goin to be 90 degree could it fit that .8'':confused:
I think it may fit. Looking at the pictures of the case with ATX motherboards installed there is "maybe" 3/4 to 1 inch of clearance between the motherboard and the hard drive cage. If you remove the HDD cage it will fit with no clearance issues.
It's only .8" taller than ATX spec which is just over 3/4", it'll be fine.
The HD cage is not removable in the FT02 as far as I can tell (short of drilling out the rivets), it should fit fine though. There's a gap on the bottom of the motherboard between that side and the HD area of about 1" to slightly more for cable feeding and whatnot. You can see the gap in my shot...
Do a test fit. You should be able to line up the board with the screw holes and tell whether or not it'll fit pretty easily without having to open any of the accessories, and you should be able to return it real easily if it doesn't fit. I think it will fit ok though.
....HHHHhhhmmmmmm Come on dude don't temp me!!!...Im in the process of sendin' it back & goin' with the MSI 890FXA-GD70 AMD 890FX ...I don't really want to send it back & @ the same time if i open the box i will get charged 15% stock fee on the RMA :(
But i really would like to know if it does fit & its not that big of an issue!:confused:...I see your rig nice!...And thats build im goin' for...Love that SSFT02..............Is Your Gigabyte Dimensions 12.0" x 9.6" ???
Officially there's no support for EATX on a FT02, but you should be able to nudge it in according to that pic.
Bright side is newegg probably wont charge you the 15% if you exchange for an 890FXA-GD70/Crosshair IV.
....Might just open it & find out!...Dont like that Red & Black look zero2dash whut Gigabyte Mobo you have?
Well, it's takes up 8 pci slots and your case only has 7. The top looks like that last slot might not fit in w/ the dvd drive. If you don't want to risk it, just exchange it for a UD5, it's the same board minus the extra PCI-E slot and the fancy NB cooling.
