Hey,
I moved to Vista today,
I have to say, I really like it, once you disable UAC, it's like XP+
But I have a small problem.
I don't know why, but I have a hard time with Vista's glassy theme.
Explorer and taskbar being translucent makes it really hard to concentrate on files at hand, with all the new background and colours and new blue gradient coloured menus.
Let's be honest if you don't use Aero on Vista then what's the point?
Anyone else having the same problem? do you get used to it eventually or did you go back to classic?
