Hi,
I have just assembled my computer and for some reason it will not turn on. I can hear no fans moving nor see any lit LEDs. I believe I have all the connections in correctly so I'm unsure what to do next. I also see no switches on the power supply to turn it off/on. I have the 24pin power connector hooked up to the board as well as the 4pin 12V connector. Should I at least hear the PSU fan turning when I press the power button? Any suggestions?
Specifications:
i3-530
Motherboard: http://www.newegg.com/Product/Produ...420&cm_re=gigabyte_h55-_-13-128-420-_-Product
Case and power supply: Antec nsk1480 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129040&Tpk=nsk1480
Memory: 2x2gb ddr3 gskill 1600
hdd: western digital blue 500gb
Specifications:
i3-530
