Computer wont turn on, having trouble finding out whats wrong
chgode
I was on my computer playing a game and all of a sudden it shut down. I assumed it just got to hot cause the case felt warm so i left it alone for a few hours then came back and tried to turn it on and got nothing. When I turn the power on in the back the DIM light goes on..on the motherboard. Then when i press the power button on the front i can hear a faint little click from inside the power supply. I reset the mobo and still got nothing. Made sure everything was plugged in tight and then blew out all the dust just to make sure it wasnt shorting out from it. If anyone knows anythign or how i could find out whats wrong it would be fantastic. thanks
system:
p4x266-8233 -via
p4 1.4 gig processor
512 ram
manually reset the bios first... see if it turns on then
if that doesn't work try an extra power supply
your symptoms sound like it's either a power supply problem or a over cooked cpu
you can take your power supply to a best buy or other computer place and have them test it
Was the case hot by the power supply? If so get that bad boy replaced. The power supply most likely is being overdrawn.
I did it the hard way a while back and cooked one. Kinda knew. I used to put my feet up on my system to keep them toasty warm.
lol
Thanks guys. I have a few more questions now
How do i manually reset bios? I cannot even get into bios.
My entire case felt pretty warm.
I myself am kinda thinking its my processor but i hearde if your processor goes bad then the fans still work, and those aren't comming on either.
If my power supply was in fact bad or fryed, wouldn't the light on the mobo not come on when I turn on the power supply?
Light dimming....
Well not unless your power supply is shorted. That could be why it is slightly dim but not lit. And to reset your bios, which isn't going to do any good cause more than likely your PSU is fried, open your case and find a jumper labeled cmos. Check with your instruction book on this, but on most computers it is a jumper on 2 of 3 prongs. Move the jumper completely to the other side. Let it sit for like a min. Then move the jumper back where it was and turn your computer on. *IMPORTANT* If you are gonna try to reset the cmos, be sure to first turn the computer off and then unplug it. Honestly though, your PSU is shorted. Get a new one, problem solved.
