computer won't stay on after loading up
deLuxe.EPiDEMiC
sometimes when i turn on my computer it will shut off sometimes during the load up and sometime it gets to after my place where i log in after it loads up for a little bit in my desktop it will turn off also. what is wrong with it? btw this computer is from 2002 not newly built. i've been running my comp at 100% capacity or whatever in task manager. for like 6-10 hrs a day for liek 2 weeks min.
Randomly turning off (as in completely off) is almost always a sign of a bad power supply.
Given the age of the computer, and the seemingly random occurance, it could also be over-heating.
Always check the simple stuff first. Clean the dust out, and re-apply termal material between the CPU and its heatsink (if it's an Athlon XP be care not to crack the cpu die).
If that doesn't help, then move on to the power supply.
Did the Athlon XP even have overheating protection? IIRC when AMD introduced that feature it was dependent on the motherboard, and many didn't support it.
Check the CPU fan to make sure it's spinning up/not clogged with dust. Unless you've pulled the heatsink before I would leave it on. Thermal goop doesn't go bad.
My first guess would still be the power supply.
My K6-2 had temperature monitoring in the BIOS and numerous times shut the system down when my fan would quit working. I'm sure this Athlon XP board would have at least that much protection, it just wouldn't help in the case of an instantaneous loss of cooling (e.g. heatsink falls off)
And yes, thermal goop does go bad. I've fix many older computers with overheating problems by replacing the thermal material, be it pad or paste.
I should have said usually doesn't go bad. As long as the heatsink stays in place the thermal compound should be fine for many years. I've repaired hundreds of machines and I've only replaced the the TIM on two.
It's worth keeping in mind, but I would still suspect the power supply first.
Well, for some reason it's working now. I turned it off at 10:30 PM last night. Then tried to turn it on at 6:30AM(when I was having troubles) and now i turned it on at 2 PM it works. And yeah I played around with the HSF.
Like I said, when you take into consideration the age of the computer in this case, overheating becomes a possibility that's worth checking into. Always start with the simple stuff.
Fixed it thanks guys. I also fixed my problem where my fps would drop so low with a 1600PRO radeon. I took apart the PSU and found that i had clumps of dust in there =X!
