Computer won't start
3far4shot
hi,
i have built a computer but when i turn it on it makes no beeps or wont boot to bios or nothing but everything works
specs
AMD 3200
ATI X1300
cheap ram
Gigabbyte K8NSC-939 (trition series)
thanks
1. Check if your power supply is plugged in
2. Check to see if your power supply is turned on
3. Check to see if your on/off switch/reset switch is in proper order
4. Make sure your HSF is connected to your MoBo
5. Make sure your CMOS switch is in the proper position
6. If all of that is correct, start swapping out parts starting with your PS.
So do you get to the post screen? do the fans all spin? have you got the psu plugs in the right places? gotta be more specific.
1.) yes
2.)yes
3.)yes there in proper order
4.) i dident check that yet
yes i get no post screen but the fan spin the psu plugs are in the right place, everything works exceps when i start it up i see nothing on the Screen not i dont even here a beep , i have a dell monitor (not sure what model) all the fans spin but like i said there is nothing showing up on screen
1) Re-Seat the CPU
2) Check if it posts now
3) If not, Pull out the ram
4) Do you hear any error beeps when you try to boot now?
5) If not, make sure the system speaker is plugged in correctly
6) Re-seat the vidcard and check if it will post
7) If not, you may have a faulty board or PSU
8) Test the PSU
i did seat and reseat the card nothing happend, the fan still spins on teh video card,
1) Re-Seat the CPU
8) Test the PSU
1,) Did that already dident post at all
2.)pulled out the ram tried dif slots, used bros ram no post still not even a beep
4.) no beeps at all but the fan still spins
5.) ok ill see if thats teh problem
8.) how do i test the power supply
also what if i take it out of the case will that work, also when i put in USB in my case (not the motherboard USB) it makes a short like the fans go slower i though it was weird and i though iti was the problem with that thx anyway ill keep trying
disconnect everything that isn't necessary. i.e. Only have your video card, RAM, and CPU plugged in. Don't have any harddrives, CD drive, IDE cables, USB cables, etc. into the mobo or PSU.
The best way to test a power supply is to install it in a known good system and/or try another PSU in this system.
ok ill try to do them both , also when i power up the system everything gets power except the CD-ROM drive but everything else gets power
ok i rremoved the CMOS battery and nothing still happend and i also disconnected everything expept ram, cpu, and vid card.
i came across this thing i dident see before when i put the USB case header on the motherboard and put a usb into the case the PSU make this weird fast ticking sound and everything turns off but when i take out the usb header on the motherboard everything is fine when i put a usb in the motherboard usb's they dont get any power or anything i think its the power supply (btw its some cheap compusa psu)
ok now i have another problem when i take out the IDE for the CD ROM drive it works and the tray comes out but when the IDE is pluged in the motherboard it dosent work it dosent even show the green light. im confused:confused:
It sounds like you have your IDE cables put on the wrong way (pin 1 oriented wrong). It can sort of create a short that can actually keep some systems from booting.
Did you do what I said to unplug all cables everywhere (except for the power supply to motherboard)? (that includes removing the power going to all of the harddrives and CD drives)
You may also want to take the motherboard out of the case. You may have a short somewhere else (for example, if you have an extra motherboard standoff behind the motherboard where it shouldn't be).
/edit: does your power supply have the separate square 4 pin power lead?
i thought they only went in 1 way but i will try
Yes i did that and still nothing happend
my PSU does have a 4 pin power lead and i did put that in and still nothing happends ill try to take out the motherboard
i also have a quick question do i need the OS to boot to bios or should it just do it itslef
No you don't, so there shouldn't be a problem here.
Does your power supply have a 20-pin or 24-pin motherboard connector? And what connection do you have on your motherboard?
20 pin and a 20 connection on my mother board
i still think its the psu or the motherboard it makes no beeps or anything nothing still shows up on screen and i took out the CMOS battery so i dont have any other choice but to remove the motherboard and try that or just change the PSU or mobo
are there supposed to be any lights on the motherboard, if so mine dosent glow or show up
make sure you leave the CMOS battery in once you clear the BIOS. Some motherboards will not POST without one.
i did already 2 times, seated and reseated the vid card, reseated cpu, took out of case, change memory and still nothing so i guess its the motherboard any suggestions?
Yah, sounds like the board. Did you try another PSU?
If that board is no longer under warranty, you can pickup a rather cheap 939 board from the FS/FT subforum.
no i seem to not have a spare PSU atm i though it was eather the board or PSU sence i both got them from compusa i was a little buget experment for a friend, i think the board i no longer under warrenty im gonna go look up other cheaper boards for a try thx anyway!
