Computer won't start, just reboots repeatably...
ap3rtis
So here's what happened:
I finally got around to installing the Accelero x2 for my x1950pro, and all seemed ok... I ran 3dmark06 with the new catalyst 7.5 just to stress it and see how hot the temps would get. I came back upstairs to a blank screen and my monitor was in power save mode, it couldn't detect a signal. That's weird I thought, but the computer was still on, so I powered it off. Turned it back on, things seemed normal.
Then today, I go to try far cry with the 64-bit patch, and after about 30 seconds of play, I get a blank screen. Try this again after a reboot, another blank screen. I thought maybe it was the 7.5's, so try again with the old 7.4's. I get the same thing.
I thought maybe it was a temp thing, and maybe my load temps were getting insanely high. So I download the folding gpu so I can monitor the temps. Just as the folding starts, I get a blank screen. Now I go to turn off my computer and turn it on again, and trouble starts. I notice nothing is showing up on the screen, so I'm like WTF? I look down at my computer, and it appears to be shutting on and off repeatedly.
Since I thought this was a video card problem with the new cooler, so I get the computer downstairs and take the video card out, the cooler looks ok, so I remounted it. Without the gpu in the case however, I boot the computer. Again it just turns on for about 2 seconds, fans spin up, and then powers down. It just does this constantly, on, off, on, off, etc...
So I don't know what to do, I think it must either be the power supply or the motherboard. When my roomate gets back I will try his power supply and see what happens, but till then... Anyone have any ideas to what the problem might be?
Thanks!
Assuming the GPU temps are ok, first suspect is power supply to the card or the PSU unit itself.
Try a different power connector to your graphics card if possible.
Unplug anything thats not necessary like CDRoms, PCI cards, USB devices...
If that works, a component could be faulty that is now unplugged or your PSU is degrading.
Let us know what happens with your mates PSU.
well I'll let you know the temps seemed ok, folding only ran for like 2 seconds, and the temps before that were around 49, I doubt they could jump up that high in 2 seconds. I guess it's possible that the power supply is going and couldn't supply the card with enough power and the card just shut off? My roomate isn't getting back till tomorrow, so I guess I'll wait till then.
I was thinking about the power supply, and could it be the power supply? If I turn on the computer, and it just keeps shutting on and off, could the power supply do that by itself or does it need some command to turn on? Maybe the power button or whatever is messed up and it just keeps signaling the power supply to turn on and off?
One thing can make your PSU properly shut off and power on again (apart from itself when faulty) and that is your power on switch.
Try unplugging the 2 pin Power connector from the motherboard and manually short the terminals to power on the pc.
If that works fine, your Power switch is shorted.
The PSU sounds like its shutting itself down, maybe not fully as it seems to reset before complete shutdown and powers up again.
This will be due to it being faulty or being overloaded.
Given the mode of failure it exhibited (slow death) prior to getting the problem you now have, it is either the PSU being overloaded (ie a faulty component, maybe even graphics card), or the PSU can no longer cope with the power needs of your system - I spose you'd call this faulty for a 520W PSU on your system.
Try unplugging all unnecessary things to leave as much juice for the rest of the system.
If this helps, I'd say you need another PSU.
How can I short the power pins on the motherboard? just touch them together with something metal? I'd be afraid of touching other pins as well, so I don't know how well that would work. Could I cut the wire that goes to the power pins, and then just touch the 2 cables together? Would that work? Then tape it back up when done?
lol yes you could.
How about taping up the end of a screwdriver so only the very tip can touch anything.
Use that to short the tops of the 2 pins.
Nothing around there carries heavy power or will fail if shorted momentarily, so as long as you dont push the screwdriver down to the motherboard surface, you cant do any damage.
I find a cross head screwdriver feels more precise and is easiest to short the pins with.
well I found out that clearing the CMOS worked, no more stupid reboots when starting the computer. My screen still went black when I played games, so I put the stock cooler back on and it doesn't seem to crash. kinda weird. though I now get graphical corruption in far cry 64, but that could because I couldn't shut down properly so maybe a file got corrupted. It wasn't like that before with the accelero x2, so who knows lol. very weird. stalker and wow didnt have graphics corruption so I figure its like the game, not the hardware.
I'd say you still have a problem but not quite as severe.
Declock the PC a bit (ie make it run slower) by reducing the fsb say 40MHz.
If that stops the problems, let us know and we can troubleshoot it.
