Hey guys...having some problems with one of my computers. Here are the specs:
C2D e2200
Asus P5N-E SLI motherboard
Rosewill 500W PSU
GeForce 7300GT PCI-E
2 x Seagate SATA 250GB in Raid 0
1 x 180GB Samsung IDE
NEC DVD/RW
2 x 1GB G.Skill DDR2 800
Okay, so the last time the computer was used was Friday. My sis printed out some maps for her San Diego trip and then I guess turned the machine off. Meanwhile, I was in the midst of my water cooling install, and decided to check something online. But, when I hit the power button, nothing happened. I reset the CMOS, and tried again. This time, the PSU + case fans started spinning up for less than a second before everything turned off. I removed the memory and tried again, and then each stick alone ...same thing. Then I decided to test the PSU ..so I shorted those two pins out and turned it on - all the case fans worked. Now...when the PSU is connected to the motherboard, the LEDs on the board are on (not sure what they refer to...but looks like power's getting to the board).
Now...I don't have an extra socket 775 cpu laying around (just sold my e6420) so I'm not sure whether the motherboard has died or the cpu. The e2200 was running at 2.8 w/ relatively low voltage (<1.4V I think)...I had throttled back on overclocking since the machine isn't really used for much more than printing and family usage.
I do have another motherboard - an MSI P6N SLI-FI. Like the Asus board, it's an nvidia 650i board.
Since I'm relatively sure the PSU is okay ..should I stick the CPU in the other board and see what happens? I'm guessing if the computer won't start w/ either board, the CPU may have died.
Otherwise it's the mobo right? Any suggestions on what I should check for would be very helpful. Thanks!
C2D e2200
Rosewill 500W PSU
NEC DVD/RW
