I posted this thread in the "motherboards" section, but as I don't really know if it's a mobo problem, I'm posting a copy here. Mods, go ahead and delete one or the other whichever one is more off topic.
Just purchased the Asus P4P800 Deluxe along with a P4 3.0Cghz HT compatible processor retail box
I attempted to replace my current mobo and processer with this combo, however, on power on, nothing happens, no beeps no power on self test, nothing...the instruction manual says that this means the POST failed, however after checking all the connections and jumpers I have no idea what caused this failure. Here are my current system specs:
MSI 845E MAX2 Motherboard (Intel 845E chipset, 533 MHZ FSB)
P4 2.53 ghz (no hyper or anything)
Gainward 128 MB Geforce 4 TI 4600 (AGP 4x)
2x 512MB DDR400 PC3200 RAM
Master Primary IDE: Western Digital 250GB 8mb cache HD
Slave Primary IDE: Western Digital 120GB 8mb cache HD
Master Secondary IDE: OptoRite DD0401 DVD+/- RW
Slave Secondary IDE: Random DVD-ROM
SB Audigy
Random LAN Card
As far as I can tell, all of this should be compatible with the new mainboard/processor. Is it necessary to upgrade mobo/processors on a new system? IE a formatted HD etc? I don't want to reformat, I just want to upgrade my motherboard and processor.
I am not using RAID or SATA or anything like that currently. I know all the other parts work as well since I'm typing with them right now (switched back to my old mobo/processor to get some tech support)
Any help would be appreciated. Thanks in advance.
Kevin
SB Audigy
Random LAN Card
Kevin
