Computer won't sleep/turn off
tronics
I'm having an annoying problem where if I put the computer into sleep mode, it will go through the process, turn off and just a few seconds later come back on.So I ran the "powercfg -lastwake" command, and it shows its the network card waking it up. So I proceeded to check the bios to turn off WOL, however this motherboard doesn't have that option or at least I couldn't find it. Also another problem which is similar is it does the same thing when I power off the computer, it turns back on a few seconds later. Unplugging the Ethernet cable doesn't always solve it. Any ideas?
Specs
Gigabyte z87-hd3
i7 4770K
16GB CORSAIR Vengeance CML8GX3M1A1600C10
GTX 760
120GB OCZ vertex 3
Windows 8.1
Check the BIos to see if the Power off state is set to "last" its unlikely but that's a possibility
I Would reset the CMOS and perform a Long POwer drain (2+ mins) seems Hardware related.
That seems to have fixed the problem, tested sleep/shutdown a few times. Thanks for the help.
