bonkrowave
- Oct 12, 2004
For starters Boo-urns
Well this morning I had quite the situation with my computer. I turned it on, powered up fine, then went to take a shower. When I came back the computer was off. When I pushed the power button the fans will rotate and lights will go on, but only for a milli-second. Any additional attempts will not cause the fans to spin, nor lights to go on, until I flick the switch on the back of the PSU and the power bar. I was having problems with my PC powering down for no reason about 2 weeks ago, but it seemed to stop .. that is until today.
My assumpton is that the power supply went. The power supply is an Energ-max(SP) and has been around for 3 to 4 years.
I went out a MOD stream PSU that I will install later tonight. Before I open the OCZ Modstream, and voided any return chance, I just wanted to see if people agree with my assumption.
My specs are below. I very much doubt it is a heat problem ... as I have 5 fans (2xback, 2xfront, 1x blowing across videocard.
