Computer Won't Power Down After Shutdown
Drklighter
Greetings...
Preliminary:
A short while ago I built my friend a new computer system. This system is VERY close to my own in hardware and software. I have been working with computers for more than 20 years, and I have a small hobby-business of building/working on PCs and related software. The problem I am having with his system started about the time that I built the system, and has lasted through various hardware/software changes.
The Problem
After using his computer for awhile, when he goes to Shut Down (to turn it off), it will sometimes shut the "system" off (HDDs/OS?) but will remain powered on. This happens randomly without any sort of pattern I have been able to discern so far. I have Googled the heck out this issue, but it doesn't seem to be a well-known phenomanon.
The Current System
ASUS M2N32-SLI Deluxe Wi-Fi MoBo
Athlon64 X2 6000+ CPU
Corsair XMS2 2GB PC6400 DDR2 (2x1GB) Dual Channel RAM Kit
2 x eVGA 8800GT 512MB Graphics cards in SLI (latest non-BETA Drivers)
Soundblaster X-Fi Xtreme Music PCI Card
LG GSA-H55N SATA DVD Super Multi Burner
LG GSA-4163B IDE DVD Super Multi Burner
3.5" Floppy Drive
WD 250GB SATA2 HDD (Primary, with WindowsXP Home SP2) *Dual Boot*
WD 250GB SATA2 HDD (Secondary, with WindowsXP Pro SP2)*Dual Boot*
PC Power&Cooling Silencer750 750W Quad-SLI ATX 2.0 PSU
Silverstone TJ-07 Tower Case with LOTS of air cooling
All latest drivers and DirectX
AVG Anti-Virus
Logitech G15 Gaming Keyboard (USB)
Logitech MX1000 Wireless Mouse (PS/2)
Wireless = DISABLED, Internet/Network via onboard GigaLAN
What I Have Tried
> Current Video Cards replacing OCZ 8800GTX 768MB
> Replaced second SATA DVD Burner with IDE Burner
> Current PSU replacing Enermax Liberty 620W PSU
> Reformatted and Reinstalled Windows on both drives
> Removed X-Fi, tried onboard sound and NO sound at all
> Disabled Firewire
> Reinstalled several drivers
> Disabled nVidia Driver Helper Service
> Changed LAN Ports
> Changed LAN Cables/Router/Connection
> Both HDDs are new & Replacements
> Shutting Down Hot & Cold (happens under both circumstances)
> Nothing in Error Logs
> Used Tweak Manager to enable "Power Down After Shutdown" Reg Entry
> Checked all Power Management settings in BIOS and Windows
> Have tried a number fo other "little things"
What I Have NOT Tried
> Using another Keyboard & Mouse (Trying that next)
> Replacing MoBo, RAM and/or CPU (Can't really dot his unless I know that's the problem)
> Replacing PSU (This is the second one we tried, I can't believe we'd have that bad of luck
> Reinstalling bare Windows again, then see if it happens with just the OS and no other software (I'm sure it happened on my last reinstall though).
> Adding Ethernet card (no available slot without pulling X-Fi)
> Updating BIOS (There's only one newer and it says it's only for CPU support)
I'm not sure what else I can do... I'm leaning towards this being a hardware issue, but I just can't tell him to start replacing key parts without at least an idea of what's wrong. Keep in mind, other than the video cards (I have a 8800 Ultra), SATA Burner (mine are both IDE), PSU (mine is a Silverstone 850w) and wireless mouse (I have a Logitech G5), we have virtually the same systems... I have the same XP Pro install on my main HDD that he has on his Secondary HDD (the one I am using to troubleshoot). Other than the AV and his use of iTunes we have nearly identical software as well... and I have NO issues.
He is a friend, but I am not about to start pulling my system apart to provide "test" parts for his MoBo, CPU and RAM... I need some more direction as to the problem. If anyone could offer some concrete advice/assistance I'd truly appreciate it.
Thanks!
UPDATE: Changing APM to S1, changing KB and Mouse to other PS/2 and disabling USB controller all still result in shutdown problem.
UPDATE: Tried new PSU - didn't fix it... going to assume it's the Mobo. Going to do a stripped down out-of-the-box test this weekend as a final test though.
Sorry if I didn't see it in your post but has your friend tried formatting? Honestly, my Windows XP installs would usually do that after 8 months or so.
did you try editing the registry in order for this to work? it should be working your computer should be shutting down all the programs if its stuck there -> task manager find out whats keeping it from shutting down after the first couple of attempts to manually shut it down.
last resort is reformat.
Update: After extensive testing, I have decided that the problem likely lies in a bad USB controller on the MoBo... it's been RMAed.
