Computer wont post :(
Atherton213
hmmmm :( this really sucks my Abit board.... the matx one in my sig....stoped working it has been working perfectly without any issues
Ok I have it connected with HDMI and like i said been working great.... today i got an HD-DVD player (yay deal... $150 cause it had a scratched up box) so i turned my computer off to borrow the HDMI cable.... well im done playing with the dvd player. I go back to my computer plug it in.... and BEEEEEP its just 1 long beep then stops and then long beep again. I thought it was my ram, so i took one out to try just one and same thing. I tried both sticks in all 4 slots. same thing, so i took the ram out completly and its just one long beep with no stoping, so the beep im getting has to be some other issue?
i dont get why it was working fine and all i did was take the cable out and put the cable back in and it stoped working?
hopefully its not my board :( that would suck
Did you try resetting cmos? Reinstalling cpu? Did you OC? If the mobo beeps withour ram, it's a good thing... if it didn't beep at all, it could be dead.
Try booting with no peripherals as well.
Resetting cmos is a good idea. I'd also suggest trying a known working power supply. Next after that would be reseating the cpu.
Look up the beep codes????
Graphics card come loose???
short??:eek:
yeah i tried resetting that a a few times... it was never OC'ed and ive re-sat everything
the beep is about 4-5 seconds long then stops then another 4-5 seconds...keeps doing that
with no ram in it, its one long solid beeb with no stops
i cant figure out what it is from doing a search for the beep codes cause the long (with no stops) = no ram and then there is nothing for the long 4-5 second beep
?? im thinking the issue is the board... ive heard from other people it worked fine and then just stoped working :(
EDIT: its on board video
