Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
yes it does. it's the xclio 450bl. the only thing I've noticed is that it's making a faint whining noise now. I had a 370w enermax and upgraded to this because the computer wouldn't boot, but I think the floppy was the problem with that as well. It seems that the psu works with the floppy on first use and then fails.
if the cable isn't keyed and then is plugged in upside down, I've seen this happen. As always, verify that pin 1 on either end of the connection is going to the colored wire.
