GOD'SlittleSERVANT
- Jul 18, 2001
Just installed stuff you see in sig. After turning on computer it keeps rebooting....what can the problem be?
n3g471v3 d3c1b3l said:When you say you just installed all that hardware..... are you using a preivous install of windows from different hardware????
TheMostWantedPolishTwin said:that's a really good question.. cause if you didn't reinstall the OS, most likely it won't boot up..
