scottatwittenberg
- Apr 10, 2002
biostar 6100-m7 motherboard
1 gb corsair vs
s64 2800+
antec smart power 500w
wd 80gb 8mb cache ide
so everything was working fine... then i went a changed the fsb from 200 to 210.. after that, the computer didn't boot.. so i put the fsb back too 200.. it still wouldn't boot.. it would get to the "veryfying dma data..." then it would show boot from cd-rom drive things.. i then discovered that i could get it to boot if i hit tab to show the normal post screen instead of the fucking biostar splash screen, then from there click F9 and choose the hard drive and it would boot..
this was last night using a 350 watt codegen psu.. today we got the sp 500w hooked it up.,. and the thing booted all the way into windows without any problems.. this was on a 60gb 2mb cache maxtor though.. we dropped in the wd 8mb 80gb drive.. installed windows.. and all was fine.. but now it won't boot at all.. it goes through the post screens but just blanks out after the verifying dma data.. thing...
so.. i have a feeling that the ide channels crapped out..
i have reset the bios with the jumper 5 times or so..
i have tried the hard drive on both ide channels..
it has done this with 2 different hard drives
it has done this with 2 different psus
it has done this with only 1 stick of memory.. and i tried both individually
what should we do next? update the bios?
when it does boot into windows it runs fine..
i am thinking that we might have to just rma the board.. i wish we had an sata drive to try on it..
also.. the voltages are all low.. even with the new psu, which has dual 12v rails...
thanks
scott
1 gb corsair vs
s64 2800+
thanks
scott
