Computer with 8x dvd burner FS.
funboy6942
Amd 1700+
BIOSTAR M7NCD
WD 7200 40 gig
512mb pc2100
Sapphire 9500NP soft modded to a 9700
Broken ati tv tuner (tv doesnt work but the inputs do just fine)
Lite on 8x +/- dvd burner with homemade stealth front plate attached (when you open the front cover it looks like you have no drives installed)
Wrapped up in a ALIENWARE (Chieftech) case (Lime Green)
Will install any os you wish (as long as you also have the same os boot cd)
Will install ALL updated drivers for all hardware
Will install all needed software to run
Will also install anything else you find needed on the system that you need (example: freeware games, bench software or programs, ?? what ever.)
And after done with all that I will run 24 hours (3dmark2001 looped) to make sure it all works before you get it. Not saying it wont I am using it right now just after installing all the drivers it could have a glitch or bad install and will make sure it gets to you running 100% and ready for you to use.
BTW gets a score of 11500 with the mobo fsb at 135 and the video card at 295/295. Can go faster but I dont feel the need to try it or run it any faster.
$550
Email me through my profile if you want some pix
Tanx for looking
BTW Not a noobie here. Havent been on for over 7 months and for some reason I had to re-register :( Was registered before hand for about 2 years. Heat under funboy42
Pictures can be seen here of the computer.
Bump because I have been a member of the [H] for about 4 years but also had to re register because of account inactivity I guess.
If you ever decide to part out. Dibs on the LITEON~ for my shuttle.
I parted out my system recently and got more. :)
-CaL
Thanks for the bumps and I wish I could part it out but I cannot. I am using it for the moment and need it all to go at once so I can put together a shuttle comp of my own.
Now if you have the shuttle I am looking for and wish to maybe do a trade I may be open to something :)
Now have pictures bump. Thanks hitman. It really is a good and extreamly stable system. Stays on 24/7 without one fart.
