Computer Will Not Start - BIOS issue
CAS
I recently got a new system together and was trying to get my SATA HD to work, but the system kept saying it could not recognize any HD. I would hit F6 when prompted to install 3rd party drivers and install SATA drivers, but my HD would still not be recognized.
I thought that perhaps I should update the BIOS of my MB. Well I tried but did something stupid. I hit Alt + F2 at start up and did not have the floppy in the Drive. So it could not find the file. I then popped it in, hit a key and it found it, did something and told me to turn off my computer then turn it back on.
When I turned it on, it went straight to searching first my floppy, then CD drive for A8V.ROM which is the file on the floppy. It would find it, do something, then tell me to turn off my computer again, then turn it back on. This would repeat over and over, until I just restarted the computer and I got a blank screen.
I turned off my computer, turned it on...blank screen. I turned off the Power Supply, Unplugged the cord from the PS, unplugged from the wall. Removed the battery, cleared the CMOS, put battery in, plugged everything, turned on PS, turned comp on, and NOTHING. I did this like 3 times and still nothing....What theh ell could I have done? I am sooo worried right now. Here are my specs:
Asus A8V Deluxe
AMD64 3200 Winchester
PDP 2x512
Raptor 74 gig HD
Plextor CD/DVD drive
If someone could help me or reassure me that screwing up the BIOS will not harm my components, I would appreciate it, thanks!
EDIT: Hmm, seems if I put one stick of ram in the 3rd slot the comp will turn on...gonna play with this
