- Mar 31, 2008
Hello,
I am working on a Dell Optiplex GX240. When I power on the pc, the dell logo doesn't display, the display is blank for a minute or two then it shows Windows XP with the status bar and then goes to a BSOD. So, I would like to reformat the computer but I can't since I can't see the BIOS, I pressed f2 to get to it and it doesn't do anything. I reset the BIOS that didn't help. I pressed f8 and the advanced windows menu didn't show, so I can't boot into safe mode either. I tested the motherboard by pulling out the ram and it produced error codes so I know the motherboard works, but for some reason the Dell screen will not show on start up and I can't get to the BIOS. What else should I try?
Thanks,
Matt
Thanks,
Matt
