I built my first computer for my fiance about a year ago and up until now it has been running perfectly. Here are some of the specs:
2GB OCZ 800 mhz Ram
Intel E6400
250 GB Western Digital HD
P5NE-SLI Motherboard
320 mb 8800GTS
Windows Vista
I was in the middle of playing a game and the system froze. I tried to ctrl+alt+del but it remained unresponsive. I decided to try a hard restart and when it got back to the Windows loading screen the system froze again. I restarted again and I got the menu asking if I wanted to boot in safe mode. I was able to get into windows and I put the Vista DVD into the drive but I was unable to access it and the auto start was not functioning. I tried to restart again with the OS disk in the drive with the hopes that it would prompt me to reinstall Windows or repair it. The screen went blank and it was remained that way ever since. I have tried starting it again repeatedly but now I do not even hear the beep the motherboard used to make when it first started. Also the screen that shows the motherboard name and information doesn't show anymore. Basically I turn the computer on and the fans run and that is the only response I get from it. Nothing else happens.
When I built the computer my one fear was what would happen if something went wrong and I needed some technical support. If anyone can provide me with some information about what might be wrong with the system or some steps I can take to repair that would be amazing. Any help that you can provide is appreciated. Thanks in advance for your responses.
2GB OCZ 800 mhz Ram
Intel E6400
320 mb 8800GTS
Windows Vista
