computer turns on then turns right off.
XteriorMotive
Ok so here is my Dilemna. I have recently put together a system of old parts for my sisters and whenever I turn it on the fans spin and the drives show activity for about 4-5 seconds then it turns off again, doesn't even get to POST. I have read a few threads on other sites with people having similiar issues and none of the suggestions there have helped me. I have removed cleaned and reinstalled the cpu heatsink and applied artic silver 5 and have tried getting down to the bare minimum amount of hardware running and also tried 3 different PSU's and it always has the same issue.
Specs are.
AMD Athlon XP 2000+
Gigabyte GA-7VA Motherboard
512MB Generic DDR400 & 2 sticks of 256MB Geil DDR400
XpertVision Radeon 9800Pro(Have also tried Asus A9250)
40GB and 80GB Seagate IDE Drives
2x Lite-on CD Burners
Psus I have tried have been a 500W and 2 550W Generic units(Don't have any brand name units to test.)
Please help someone.
Thanks in Advance
Xteriormotive
It shouldn't be the processor doing it that fast unless your heatsink is on VERY wrong... you should at least be able to get into BIOS at that point. Check your memory. If you have 3 sticks of memory, try only using one to start with. If that one does it, switch them. If that one does it, move to the next memory slot and try again. I've had bad experiences before with memory doing that before. Basically you need to try and make sure it isn't a particular stick.
You can also download something called Memtest 86; http://www.memtest86.com/download.html
If you can post at any point, you can run that to check the memory for errors. Also, check the motherboard to make sure it can handle that memory. I think that may be your problem.
If you've checked all of the memory, and you get the same problem on them all, then try other things... test the power supply by itself by unplugging the 20pin connector from the motherboard, getting a paper clip, and basically connecting the green with any black wire. Plug the power supply back in after that, and if it has a switch on the back turn that on also. It should turn on.
Try without the video card or other components. You're going to need to spend some time troubleshooting this piece by piece to find out what the fault is... you may even come with the conclusion that it's the motherboard.
I have already tried removing most of the hardware and a few of the other things you have suggested. It supports the memory I have made sure of that and even without any memory in instead of beeping to tell me its not there it does the exact same thing at no point does it stay on long enough for the screen to turn on and the award post screen to come up. I have read that it could be a short, Is there ways it could be shorting out on the case or something and how would I be able to tell?
