Computer turns on, no display
duffman03
I couldn't decide which subforum to post this in... really it could be the motherboard, the graphics card, or something I haven't even thought of :confused:
So, I just built myself a computer.
Coolermaster CM690
Gigabyte EP35 DS3R
Intel E8400 w/ Arctic Cooling MX-2
Arctic Cooling Freezer 7 Pro
2x1gb G.Skill 800
Seagate Barracuda 500gb
EVGA 8800GT Akimbo SC
Corsair VX550W
Viewsonic G90fb-4 19" CRT
I turn it on, and all the fans spin up, the LEDs work, but the monitor shows nothing. The light stays orange like it's in sleep mode. I hooked the monitor up to my old computer, it works fine.... Can anybody help me decide what to do? I honestly have no idea what could be wrong :( Orange light on the monitor generally means no video signal, so I guess the video card should be the first suspect?
Did you check if you put all the power cables in like the one for the video card? And try to reseat the graphics card to make sure it is in properly.
I've reseated it a few times, it was somewhat slanted at first cus it's a really tight fight with the bracket and the case, but it's all straight now I think. The 8800gt Akimbo only takes a 6-pin power source, and it's plugged in... Is there a chance that the video card is just plain broken, and I should RMA it?
It's possible you may have a bad video card. Do you have a PCI video card to try? If you do, see if you can at least your PC to boot using a legacy PCI video card. Or try another PCI-E video card if you have a spare one laying around.
You can try to boot taking out the mobo outside of the case on an anti static bag.
My rig did a similar thing on the first boot, I rechecked/redone all my connections looking for a short or a faulty contact. In the end it started just fine.
i hate it when you finally put things together and it doesnt work...
check to see if you switch the input on your monitor from vga to dvi vice versa...
No clearing the CMOS has nothing to do with the fact that the graphics card not providing a signal on the screen....especially when its a new computer and motherboard and all you want to do is to test and try out your newly built computer for the 1st time!
It could be that you got a faulty PSU, or a faulty graphics card....those are the only two things I would suspect of being the culprit in your case!
Also as others have mentioned this, if you have anymore spare PCI-EXP gfx cards lying around....slot it in and see if it works....that way you'd know its your 8800 card for sure......I wouldn't recommend RMAing it before trying out the things I've just mentioned!
You said it stays orange like it is in sleep mode. Does the hard drive LED ever flash?
Are you using any PCI devices like a sound card? If so, try taking it out. I know my sound card sometimes causes the exact same problem.
Double check ALL power connections, check that the card is seated right, and if nothing else switch the DVI cable to the other port on the card and see what happens.
The thread starter hasn't posted anything since 5/13, I think his problem may have been fixed until he updates us otherwise.
