I tried crossfire'ing two HD4890s earlier, but was unable to have it start (would not even power up..would light up for a split second). I figured that my powersupply wasn't good enough, so I called it quits and removed the second video card out. When I tried to boot it afterwards, the computer would turn on (but nothing showed up on the monitor). (The video card had 3 lit LED lights, and the fan was going at 100%) Apparently this is the video card's own POST procedure and the LEDs should've gone out if everything was okay and the fan would've lowered.
I figured that there was something wrong with my video card, so I replaced the 4890 with a GeForce 7900 I had lying around. I experienced the same problem (the computer would power on, but I was unable to get any video). To be sure, I brought my 4890 to see whether it was my video card and it worked fine on his computer.
I then though that something went wrong with the power supply after we tried to crossfire it (seeing that it couldn't boot up with two of the cards in). My friend brought hist 620w power supply over today, and after installing it, I encountered the same problem. Although it doesn't rule out that my powersupply is the problem (I didn't test my PSU in his computer) I guess it isn't likely that power supply is the problem.
We tested the RAM on his computer, and it worked fine as well.
I dismantled my computer, and put it back together but still a no go. I bought a case speaker today (to hear any POST beeps) but I was unable to hear any (which indicates that either it doesn't POST, or that the speaker is broken or incorrectly placed). I tried booting without RAM or a video card to force the POST beeps.
I've cleared BIOS (through the jumpers) and through taking out the CMOS battery but still nothing.
Edit: I removed all non-essential devices that I didn't need (CD drives, fans, hard drive) throughout the testing. Reseated RAM, video card multiple times. Tried using one stick of RAM.
My thoughts is that the problem is the motherboard (with the CPU unlikely being the culprit, but this is just a weak assumption).
Any thoughts? is it time to RMA the motherboard?
Thanks in advanced for any help.
