Computer Towers
carbonsteel
Im want to purchase a tower for my new computer....but i worry that my new Evga SLI motherboard and 7800GT may not fit....are motherboards not fitting, a rare issue? Here the case I might buy...how do i know if it will fit, or again, are things not fitting really rare? Thanks for your help...
heres the link to the case i wanna get....its on ebay for just over 70bucks....is that a good buy of can i get better?
http://cgi.ebay.com/ws/eBayISAPI.dl...1&from=R8&satitle=6802512478&category0=&fvi=1
thanks again for your help
Carbonsteel
sprocket said:
Your gear will screw right into that case.
i concurr, however bad experiance is often had with a cheap PSU included with the case, you may want to ask about it in the powersupplies forums before actually using the included PSU. You probably already have one better than the one included.
