Computer that I am planning to build
Framerate
I am planning to build a new computer and I think that I have found what I want, but I would like some other peoples' opinions on the matter. Here are links to stuff that i chose on Newegg.
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-908&depa=0 Antec 430W Power Supply, Model "TRUE430" -RETAIL
http://www.newegg.com/app/viewProductDesc.asp?description=27-152-032&catalog=23&manufactory=BROWSE NEC 16X Double Layer DVD±RW Drive, Black, Model ND-3500A BK, OEM
http://www.newegg.com/app/viewProductDesc.asp?description=11-999-051&catalog=23&manufactory=BROWSE CoolerMaster Blue 80mm Neon LED Fan, Model "TLF-R82" -RETAIL
http://www.newegg.com/app/ViewProductDesc.asp?description=22-144-327&depa=1 Maxtor 250GB 7200RPM SATA Hard Drive, Model 7Y250M0, OEM Drive Only
http://www.newegg.com/app/viewProductDesc.asp?description=23-126-114&catalog=23&manufactory=BROWSE Logitech Elite Keyboard USB/ PS/2 104keys -RETAIL
http://www.newegg.com/app/ViewProductDesc.asp?description=20-146-546&depa=0 Crucial Ballistix 184-Pin 512MB DDR PC-3200 - Retail
http://www.newegg.com/app/ViewProductDesc.asp?description=13-130-468&depa=0 MSI "K8N Neo2 Platinum" NVIDIA nForce3 ULTRA Chipset Motherboard For AMD Socket 939 CPU -RETAIL
http://www.newegg.com/app/viewProductDesc.asp?description=26-104-129&catalog=23&manufactory=BROWSE Logitech MX500 Optical Mouse USB/ PS/2 -RETAIL
http://www.newegg.com/app/viewProductDesc.asp?description=17-103-910&catalog=23&manufactory=BROWSE Antec 550W Power Supply, Model "TRUE550" -RETAIL
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-463&depa=1 AMD Athlon 64 3500+, 512K, L2 Cache, Socket 939 Windows Compatible 64-bit Processor - Retail
http://www.newegg.com/app/viewProductDesc.asp?description=14-125-149&catalog=23&manufactory=BROWSE GIGABYTE ATI RADEON X800 XT Video Card, 256MB GDDR3, 256-Bit, DVI/VIVO, 8X AGP, Model "GV-R80T256V" -RETAIL
http://www.newegg.com/app/viewProductDesc.asp?description=35-888-105&depa=1 Vantec "HDC-502A" Aluminum Hard Disk Drive Cooler w/ 2 Fans -RETAIL
Edited by request.
to save us the hassel of clicking on all the links...add in the names on the post....most of us will know of the part ur talking about
The Western Digital IMO is a waste of money. If you ahve the money go for it though. I would much rather have more space though.
Also what exactly ar you using this computer for and how much are you willing to0 spend? Are you going to overclock?
Get a MX510 rather then MX500. You can get it from amazon for the same price and you can get it in red or blue.
It looks like you are going to be using the PC for gaming so don't go with Intel. Get an AMD rig.
If you're building for gaming....avoid Intel like john kerry. I would suggest the AMD 3500 as it gives the most bang for the buck.
I am planning on doing some video capture, so wouldn't the WD Raptor be better than a 7200 RPM HDD? It will be usd for gaming mostly. Also I would like to listen to some music, so if you recommend a motherboard change do not recommend one with a VIA chipset. It clashes with my headset and I don't want to get a PCI USB card for the sole reason of using my headset.
Dual channel=, since you'-re not ocing=, you'-ll be wanted the 6most stable=, and 6most powerful syste6m at stock=, this will help you.
