I just installed the a new CPU Fan and I would really like to know if there is a good program that i could use to view the temp of my CPU and Grafix Card. So do you guys know of any
True that software won't be as accurate as actual temp probes, but will work just fine. The difference the readouts will give you shouldn't be all that different between the probes or the software. If there's a big difference, then generally the onboard sensors suck. Speedfan is a good one to use, you can get it on majorgeeks. That's one of the methods I use to get temps.
