CPU: Opteron 170
RAM: 4096MB G.Skill DDR500
GPU: 2x eVGA 7900GTX "Reloaded" SLI
MOBO: A8N32-SLI Deluxe
HDD1: 150GB Raptor 10k RPM
HDD2: 750GB WD Caviar
HDD3: 750GB WD Caviar
AUD: X-Fi XtremeMusic
OPT1: NEC 4551A DVD Burner (flashed 3550A)
OPT2: BenQ DVD Combodrive (52x32x52)
MON: 17" ViewSonic VA721
CASE: Thermaltake Armor Black
PSU: PC Power and Cooling 850SSI
This thing is due for some kind of upgrade come May (my scheduled upgrade time). I know that the GeForce 9 series is coming out soon. Thing is, I'm not sure how much I should upgrade. Given a 1280x1024 resolution, would a 9800GX2 suffice? Would the Opteron bottleneck it so much as to make it worth it to buy a new CPU/mobo/RAM? The more I upgrade, the more I'm tempted for a larger, higher-res monitor to be purchased at a later date.
I'm thinking I have three options within my $1000 upgrade budget
Option 1 - Minimal Upgrade
- Replace the graphics subsystem only, buy dual 9800GTX or if the PSU does not permit that a single 9800GX2 (perhaps a 5.25" PSU is in order?)
Option 2 - Moderate Upgrade
- Replace the graphics subsystem, get SLI 9800GTX
- Replace CPU with an Intel Quad
- Replace mobo with Intel-compatible SLI chipset
- Replace RAM with 2x2GB DDR2-800
Option 3 - F-ck the Budget Upgrade
- Replace the graphic subsystem with Quad-SLI 9800GX2s
- Replace the CPU with an Intel Quad
- Replace RAM with 4x2GB DDR2-800
- Definitely need a 5.25" bay PSU here
Or something else? Help and advice please! Keep in mind I'm going to SELL whatever parts I replace.
