Computer slowed down, Crashed, Funny letter in Bios HELP
WGSquallx2002
Okay here's my situation. I turned on the computer this morning. I have Windows MCE 2005 installed and while running it this morning, programs started to slow down a lot. Lots of lag-time, etc. I opened the side of my case to look for any hardware problems (such as a fan not starting up or something) and there doesn't seem to be anything.
Below this message you can find the specs of my computer. I have never overclocked my computer and I have some beefy cooling on it too. Nevertheless, let me give you more details on what happened.
I was transferring some files from one hard-drive to another and suddenly the computer monitor goes into sleep/standby mode. Then after 3-5 seconds, the computer restarted itself as I heard one of harddrives spin down and up again (accompanied by a lot of fan hustling and my case led's all on at the same time-meant the computer was restarting or starting up).
Right after the monitor comes back on, I get a bios screen full of garbled text. I can't decipher any of it at all. I decided not to continue and instead just forced off my system.
Right now I have the power unplugged and I hope I can flash the CMOS and clear any of this up. If anyone has had similar problems, please let me know.
I've also had a friend who's computer I was working on had very similar symptoms. His applications would run very slow and all of a sudden (very random), his monitor would lose any signal and it would go into sleep or standby mode as well. I hope this is not due to a virus...
I dont think this is a virus...
I had similar symptoms on my first PC... A sempron system. Applications would CRAWL whenever they had something to do (like read from the disk, swap memory etc.)
I tried a new HD and all was fine. Now, to this day I'm not certain whether it was the HD that had the problem, or whether the fresh install of XP on the NEW HD solved it. I still have the drive (a maxtor 40gb) in the desk beside me, and it STILL crawls whenever things were accessed.
Startup times, were unaffected... So I think it was an IN XP issue.
I had a laptop (Powerbook G4) that experienced similar symptoms, and eventually lost the HD. The HD died 2 weeks after the applications started acting up.
My main rig has the sleep/standby monitor issue, however... It's strange, most web-pages (containing Flash... I believe) will cause my screen to go blank for a few minutes. I've got no idea why this happens. If I dont jiggle the mouse to "revive" it, my board will eventually go into standby, and need to be woken back up using the power button...
Sounds very strange. Thanks for your input.
Well, I've been using this Windows installation for at least 4-5 months now and have not had these symptoms before. I have not installed anything lately either or had any power outtages. I haven't tested everything on my own rig as I'm basing my judgements on my friend's computer which has died.
I witnessed all the problems his computer had because he brought it over for me to diagnose. Before he took it back (I did not finish the diagnosis), I came down to two items. Either power supply failure or video card failure.
I managed to reinstall a fresh copy of Windows on his hard-drive after formatting. I was reluctant the sleep-mode or standy-by mode didn't kick in while doing all those processes. it was very risky though; as I knew if anything were to freeze (such as admist formatting), then the hd would be lost.
Well I've installed a spyware remover and an anti-virus. Both updated and scanned the whole system. I got rid of some spyware junk but the main problem still persists and some graphical anomolies appear and the system then hangs and the monitor goes into sleep/stand-by mode. The computer then tries to restart itself at this point.
I'm highly suspecting a failing PSU as I use one of those Ultra-X power supplies which are very controversial as to their reliability. It was an Ultra-X 500watts modular PSU. I guess I should aim for an Antec Neo PSU.
Page file ? what is it set to? control panel > system>advance >performance settings> check if its the ammount which is advised by it.
Also beep codes when you start your pc after the POST what are they?
More info accurate info please?
next time the pc is off, give the bios chip a good push ( its usually the one that is socketed near a watch battery) i've seen wierder stuff happen due to a slightly loose chip.. also give your capacitors a good inspection, i had an older epox mobo ( three of them acctually, and all different generations) that had the leaking cap syndrom. on one of the boards it would do what you are explaining, the others did other wierd stuff ( like randomly loosing the video, or over volting the ps2 ports, usb ports and frying a north bridge dispite it being water cooled)
It's a bad hard drive. I had 2 Maxtor 40GB drives die the same way in my wife's PC.
its called chip creek
I got the chance to open my tower up this morning and I found out some bad capitors. I didn't see these a month ago when I last dusted out my system.
I've already begun contacting Epox for RMA since its well within 1 year. I hope it has warranty for at least a year when I ordered the mobo from them.
Thanks for everyone's help. The bad-cap theory hit it 100%. I'll keep everyone posted on what happens. (now that I have to dismantle my mobo to send it in, I'll think about installing one of those high end north bridge coolers for fun).
Well this board IS the revision 2+ with the latest box design (at the time). I didn't expect anything like this to happen...bummer.
I ordered this last November (2005) too, so bad caps would have been well know already.
vanilla_guerilla said:
i thought epox had left that bad capacitor thing in the past. live and learn.
Nope, some of the older stock still out there has some cheap caps... the newer stuff however seems to be much better... Sanyo's etc.
I managed to do a virus scan and a spyware sweep right before the computer gave away and stopped POSTing properly. I hope Epox will replace every single cap and not just the ones with visible eletrolyte leaks.
Daveid said:
oh wow very weird ! i think its a virus.
I guess you missed this:
