jamespetts-2
- Apr 17, 2016
My computer (a desktop that I built myself in 2010) has recently started behaving erratically and shutting down and/or crashing with a blue screen error after waking from sleep.
The pattern is a very odd one that I have not seen before. After waking from sleep mode, it will sometimes operate without problem and run for many hours entirely stably, and have no problems at all until I next wake it from sleep mode. Sometimes, however, it will, on waking from sleep mode, operate normally for a minute or two and then either crash with a blue screen error (it seems to be a different error each time: I have had STOP errors, page fault in non paged area errors and IRQL not less than or equal errors) or simply hard resets without warning. After restarting, it will often hard reset a further number of times, usually when Windows is loading, but sometimes before Windows even starts to load, or occasionally after Windows has started again. Eventually, sometimes after I have manually turned it off and on again once or twice, it will boot into Windows without difficulty, and then again run stably without any problems for many hours until I next put it into sleep mode.
The problem first appeared last week when I returned from a week's holiday, having left it in sleep mode the whole time. I have normally always put the computer into sleep mode whenever I am not using it ever since I first built it at the end of 2010. It seems as though the problem is more frequent when the computer has been in sleep mode for a longer time, but I am not sure about this. The problem seems to have got worse to-day, as it took longer than usual to return to normal after resetting, and showed some strange behaviour which I had not seen before: the POST beep constantly repeated (several times a second) and the monitors were blank, which behaviour persisted until I turned off the computer using the power switch. This occurred twice before the system eventually booted correctly, and is now running stably again.
I have just changed the sleep button behaviour to hibernate to try to prevent this from occurring, although I have not had chance to test this yet. I am not sure whether this is a problem of sleeping specifically, or whether this is a sign of an impending system failure.
Some background to the system: I am running a first generation Core i7 950, overclocked to a little over 4ghz, 12Gb of RAM and Windows 7. I upgraded my monitors and graphics card last year, and now have two NVidea 980ti cards in SLI driving a 4k monitor. After upgrading the graphics cards, I did have some problems waking from sleep before, when the computer would be very unresponsive for a few minutes (sometimes as many as ten minutes of showing nothing on the screen at all), but this problem appears to have abated recently. I have installed the latest graphics drivers, but the behaviour of hard resetting sometimes even before getting to the Windows boot screen suggests that this is a hardware problem rather than a driver problem. I cannot remember the model of my PSU at present (it is an Antec branded unit that fits into my quiet case), but I do remember checking it when I upgraded my graphics cards last year and finding that it should be more than sufficient for my system.
Has anyone else had anything like this? Is this likely to be a specific problem, or does this seem to be a sign of general system failure?
