so I upgraded my gf's computer with a 6800GT and 1gb of ram. she has a 2.5ghz intel p4 as well. Now all of a sudden after a few days of getting everything setup and working (had some issues with norton so I uninstalled it) it randomly, or seemlingly randomly shuts down. And we can't figure out why. The only thing in the event viewer is about an ip issue, but I don't think that's causing it. She's running windows 2000 as well. I have two initial ideas, one is that it's overheating. the second is that the psu isn't strong enough. I forgot to check it when I did the upgrade. Problem is we don't live in the same state right now so I can't just run over there and fix it. Any ideas you guys have is appreciated. Thanks.
edit. I believe her system is overheating. I had her check the bios and it had a shutdown temp. it was at 90 degrees celsius and 194 F
the volts seem to be good as well. but is there any program that will tell the watts of the powersupply? cause it's not readable without taking out the psu.
