Computer shuts down, burning CD.
Exce
Hey, for as long as ive had my pc, its always had an issue where it would completely turn off while burning a cd. Ive tried different programs to burn with, ive ensured that the "shut down after burning" wasnt checked, ive updated drivers, ive uncheck "restart system" under my computer. I cant figure it out, I even got a new PSU (not just for the cd rom).
Not only does it turn off, but i cant turn it on for about 15 seconds or so. the power light blinks on and off untill i turn it back on again. do you think its just a crappy hard drive? the brand is LITE-ON and i remember my driver was "G0LF" or something to that effect.
What are your hardware components and brand of PSU?
It sounds like your burner may be loading your power supply too much. You could try giving it a dedicated molex connector, in other words make sure it's the only thing on a string of connectors.
But since this has happend with two different PSUs the problem probably lies elsewhere. But it would be good to know what your average load is vrs. available wattage so we can rule this possibility out. It's also possible your burner is shorting, and your PSU shutsdown as a safety measure. I know if you short out a USB port most computers will immediatly shut down, so it wouldn't surprise me if a similiar mechanism exists in DVD burners. So you might also try a different DVD burner.
You know you are probably right, could just be a faulty cd rom. although it only shorts when i burn. but anyways, my specs are
750WATT Powertek PSU (well was, i recently broke it and its being RMA'd back)
MSI 8800gts
100gb Maxtor HD
a 3500RPM PCI slot fan
AMD X2 4200+
2 gigs of DDR2 RAM
now i put back in my stock PSU thats only like 450watts untill i get my new PSU back.
