Computer shuts down after waking from sleep/hibernate
eli2k
I have a desktop built in 2009 that has suddenly developed a problem in the past 1-2 weeks. There has been zero new hardware changes during that time, except for the colder weather. It is also running XP.
Computer goes to sleep every night, and I wake it up in the day time to use it. Now, it will still wake up and go to the desktop, but after a few seconds it will shut off, as if the power was cut off. And it will reboot itself on its own, start up again, and everything will be fine/stable.
I've only tested this once, but if I put it into standby, and then wake it up again a few minutes later, it worked fine without shutting off. But leave it overnight and it will shut off. Sounds like a hardware issue? Any times to troubleshoot? Anyone have seen something like this in the past? I don't have any extra hardware sitting around to test individual components, so if it is unsalvagable or undeterminable I will have to move on, build something new. Thanks!
