I was looking to get some help in choosing a new audio system for my computer. I have been rockin the same Sennheiser headphones for about 5 years now and they're starting to break. I want to make the move back to speakers, plus it will save my hair from the horrible indention headphones make after I've worn them too long.
I am looking to spend under $250 on a system that's going to be used mostly for music and occasionally for FPS gaming. I don't know if it will help, but the genres of music that I listen to the most are metal, rock, hip-hop, and electronic.
I am looking for a two speaker setup with a subwoofer. I noticed a similar thread here. I can do speaker setups with wires and amps and such, but I got lost when I started reading about making mods to the speakers themselves. I can't do any of that. I want to keep it fairly simple, as I'm not exactly experienced in this field.
I really do appreciate any help given!
Edit:
If there are systems that still provide a good, clear amount of bass and don't require a subwoofer, that would work too. Again, I have very little knowledge when it comes to audio equipment.
Edit:
