Computer runs but not load
Fahey
Today I turned it on and it showed the Emachine logo and did th cmos beep.
It then went to a blank screen and thats it. I tried going into safemode but it loads about 4 of those things that show up and then it hangs.
Any solutions?
Sounds like you have a bad hard drive.
Replace it and it should work again :D
try to reinstall windows before you dump your HD, maybe your OS is just corrupted
I tried XP Repair no help went to reinstall found HD is crapping out changed it with this 40GB it installed windows but it seems when it Starts to load showing the Windows XP Home Edition and Logo with the blue bar then it goes to a grey screen and stays there.
well its not a retail emachine. Im using the case,HD, and DVD-Rom, CD-RW
Could it be the mobo.
i had a similar problem. after many frustrating hours of troubleshooting, i had a virus. try a virus scan or run the microsoft malicious file remover tool. it may not be hardware related. it wasn't for me.
