Chowder Head
- Oct 20, 2005
My computer likes to restart itself after being shut off and I have no idea why,
Allow me to tell the story in full. This was all from when I updated the BIOS using the MSI software, the kind of software that didn't require a floppy and I could update it while still on Windows.
I installed the new one but I came to realize at random nights after I power off my computer, my computer immediately reboots. The ONLY way my computer could shut down properly every time is if I disabled my LAN ports. I even checked out the MSI Motherboard Monitor page, it says there's a new BIOS to install but I already installed it. Does that mean maybe it didn't go through correctly? Anyway, a few tech e-mails later from MSI and I find out there's something wrong with my ACPI which makes sense because if I tried to change it from on or off, the computer wouldn't boot. So they told me to re-install windows.
I did a recovery re-install, just to see if that would did it. It did not so I did a complete, destructive one. Every piece of software got installed correctly without any problem.
For a few weeks my computer had absolutely no problems and I figured it was over. Well, apparently not because it started happening a few weeks and still is continuing now. It is as bad as before, with a 1/4 chance of a reboot happening but I would like to eliminate this problem because it's starting to piss me off. Does anyone have any idea what could be causing this and how I should fix it?
FWIW, here's what I noticed.
-There's a greater chance if I use something that uses the internet. A good example of this is if I was using utorrent recently before shut down
-Like I said before, I don't think a random reboot has ever happened when I disabled my LAN ports via Device Manager. But I really don't want to do all those steps every single night.
Lastly, I've also had this happen to me that might be related to my other problem. Periodically, when my computer is loading, it will hang at the Windows loading screen and seriously be stuck on there for like 3 or 4 minutes straight. If I try to restart it, it brings up the error screen saying there's something wrong with your last start up, would you like to try again normally, start in safe mode, etc.
Both problems are annoying as hell and now I'm determined to get rid of them once and for all. Any help from anyone is greatly appreciated, thanks!
