computer problems, please help
EnderW
I came home today and monitor wouldn't wake up, it was acting like there was no signal.
I tried turning the computer off, but it wouldn't turn off, so I flipped off the power supply switch.
Turned it back on, and the video card fan sounded really loud and I'd had a bit of trouble with it before so I swapped in a PCI video card. No change.
Everything appears to be fine - all the fans are turning, the LEDs on my ballistix RAM are still flashing like normal.
I've had this system for about 6 months, has been rock solid - any ideas?
Only thing I can think of is last night after I used it for the last time and went to bed, as I was lying in bed, I remember seeing a small flash of light from the living room, but didn't think much of it because I leave the side off and the light from the RAM and my Zalman 9700 always is visible from the bedroom - the flash was very small and I was almost asleep so I just wrote it off to the RAM LEDs changing or something - they flicker around a lot.
Other than that, maybe this PCI video card isn't being detected or something? I've never used one, so is there anything special I need to do?
I tried turning off for 30 min and taking out the MB battery, didn't do anything.
System specs:
Intel D975XBX2
E6300 with Zalman 9700
2 x 1GB Crucial Ballistx DDR2 800
HIS X1950XT old
ATI 1550 current
WD7400ADFD Raptor
Audigy ZS
Highpoint 2320
8 x Seagate 7200.10 320GB
Corsair HX 620W
It really sounds like a dead video card to me, but that's just a guess....If you can't get to post, there isn't much help I can offer other than try a different PCIe video card. You might want to check the voltages on your psu, and re-seat everything...
ok, I just got out my old D975XBX, took the CPU out of my main system and some extra RAM laying around and hooked it up, works fine
so I'm guess it is the RAM or motherboard that is bad, about to switch the RAM out and see, then RMA the motherboard I guess
never heard of an Intel board dying like that
