computer problem (not min)
Disable your thermal throttling in your BIOS. Here is what I would MANUALLY set my settings to:
Advanced Chipset Features
CPU configuration
CPU Thermal control - disabled
C1E Enhanced halt state - disabled
Intel Speedstep - disabled
System Clocks
CPU Spread Spectrum - disabled
HT Spread Spectrum - disabled
PCIe Spread Spectrum SPP - disabled
PCIe Spread Spectrum MCP - disabled
Sata Spread Spectrum - disabled
Also, be sure to MANUALLY set your multiplier. A 21x multiplier is obviously WAY TOO HIGH. For example, an 8x multiplier with a 400 FSB would put you at 3.2ghz (should require little to no vcore adjustments). If you are not comfortable with adjusting your voltage, most can achieve 3.0ghz without ANY voltage adjustments (375 x 8). Manually set your timings on your ram based on your manufactures rated specs (my dominator ram for example runs all day long at 5-5-5-15 @ 2T @ 2.2 volts). Your ram shows to have a max voltage of 2.1v and your timings are tighter at 4-4-4-12. If you go over a 400 FSB and you are having trouble booting, you might want to consider loosening your timings to 5-5-5-15. You have a kickin little machine and should be able to really kick that sucka into high gear...LOL.
Also, you don't have an aftermarket CPU cooler listed on your wish list. Do have an aftermarket one or just the factory Intel cooler? A quadcore will REALLY benefit from a GOOD aftermarket cooler as those quads really tend to heat up quickly.
