I have been working on a computer for the last couple weeks now. When I first got it, I put it all together and everything seemed to be working just fine. The only problem with the machine was that every once in awhile, the system would not POST due to a loose wire of some sort. A couple days after building the computer I accidently ran some ASUS NoS program which crashed my system and would keep my systeming from POSTing. I determined that this program killed my motherboard so I RMA'd the motherboard back to ASUS. I just now, yesterday, received the new motherboard in the mail. I have only hooked up the essential computer parts into the motherboard (RAM, video card, processor) just to be sure it would work. I turn on the computer and everything works fine, the computer POSTs and I am now looking at the startup screen and I can fool around in BIOS, whatever. Now, when I turn the computer off and then turn it back on. The system will not POST. I get nothing on the monitor, cant get to BIOS, I get nothing. Every so often when I fool around with the RAM, I can get the computer to POST. Whenever it does POST, and work perfectly, the second I turn the computer off and turn it back on again (without touching anything inside) the computer again, will not POST. Basically, my problem is I have a computer that POSTs and works perfectly once in a blue moon. The computer just does not want to POST all the time, only when it feels like it. What do you think the problem might be? What do you think I could do to fix it? Whats wrong with my computer?
Computer Specs
ASUS A8N-SLI Deluxe
2GIG Corsair PC-3200
BFG 7800GTX PCI-E
Computer Specs
ASUS A8N-SLI Deluxe
BFG 7800GTX PCI-E
