Computer Post Problem!
Riggd
Ok, so basically my computer posts for 5 seconds then shuts down, can any1 help me find out how i can fix that?
Also when the post light on the abit p35 pro is at ninety-nine what does that mean?
did you check all your power connections?
ALso if your 24 pin power connector is one that has a detachable 4 pin for older mobos, check to see that the detachable pins are oriented in the correct direction.
do you get anything on your screen when it posts?
