computer not turning on?
crazymonkee84
So about 3 weeks ago, I got an Opteron 165 which I put in my motherboard an epox 9npa+ ultra, with 1 gig of kingston value ram. It was fine for a while, then I started overclocking. I got a lot of potential out of the proc but I put in 3 sticks of 512 corsair value ram to see if I could get more out of it. That's when problems started happening. I would press the power switch on my computer case but only 1 blue led light on my motherboard would light up. I would then have to toggle the power switch on the psu and try again, and sometimes if it worked, then it wouldnt show anything on the screen. After a few tries, it would finalyl manage to turn on, and eveyrthing would work fine. I tried switching back to just 2 sticks of 512 meg kingston ram, but that didn't fix it. I got my new case yesterday and put everything in but that didnt fix it either. This morning I sort of noticed that the chipset fan was moaning. I unplugged all the other fans (case, processor, vf900) and it was the chipset fan. It was causing an enomous amoutn of noise and constantly going vrrrrooom then quiet vrrooooom then quiet. Could the chipset fan being broken be causing my computer to not turn on? I tried turning everythign in my BIOS back to stock as well but that didnt do anything. I'll be putting my 3200+ back in later to see if it works, and if so then I can determine that it's my opteron. But could the chipset fan be causing the problem? Thanks in advance
