Computer not shutting down properly!
ahmadka
Hey guys ... Well I have an old PC from like 3 years ago, which had a DFI SLI-DR motherboard in it ... Now recently that motherboard got shot, and I had to get another motherboard which was compatible with the old AMD 939 socket type ... So I got the Foxconn Winfast NF4SK8AA-8KRS Motherboard ..
Now with this new motherboard, I am experiencing a very strange problem. When I shutdown my computer from Windows, even though everything seems to 'turn off' (you can't hear anything), there are still signs that the PC is not 100% off ... Specifically, the computer is still supplying power to its connected peripherals !?!?
For example:
- The PS/2 keyboard's 3 LEDs are on (CAPS LOCK, SCROLL LOCK, NUM LOCK)
- The PS/2 Optical Mouse's red light from underneath is on
- I have an external 1TB HDD ... This HDD's red/write LED is flashing ..
- I have an external USB Dongle too ... This dongle's blue LED is also on ..
So all these signs point towards one thing that the PC is not 100% off when I shut it down ..
Below I am posting my motherboard's current settings from its BIOS .. please have a look and tell me if there is anything I can do to resolve this issue .. Thanks in advance guys :)
sounds more like its going into sleep mode when its turning off.. question.. when it shuts off.. does pressing any buttons on the keyboard or mouse cause it to turn back ? also you could try disabling the suspend s1&s3 stuff.. but by doing that you cant hybernate or put your computer into sleep mode..
but honestly it just sounds like its not sending a signal to the psu to shut off..
also another thing you could do is go and set the optimized default bios settings.. and see what it changes or if it changes anything at all.. ive had to do that with my motherboard.. windows refuses to start on default settings.. cant figure out why.. even though when i do the optimized settings it doesnt change a dang thing but windows will boot up.. could be the same case with that board shutting off..
