Computer no longer working: long story, please help!
strid3r
I've had my computer for a little over a year now. Here are the specs:
Athlon 1700+ @ 2.2ghz
Abit NF7-S
Corsair 512mb PC3200LL
Maxtor 80gb / Hitachi 200gb
Antec 430w True Power
BBA 9800np -> Pro
Anyways, a few weeks ago, I came home, tried turning on the computer, and it wouldn't load. It'd get past the WinXP logo, and then to the logon screen, but when I tried to login, it would freeze. I couldn't get it to boot into Windows after that. It would give me the message that Windows wasn't shutdown properly and I couldn't boot Windows normally or in safe mode. I tried running it with different ram, different video card, but to no avail. I tested the hard drives in other computers and they worked fine. I thought it was the motherboard, so I had it RMA'ed. I got the replacement board today and just finished putting it together, and it's a no go. Same problems. I noticed that I can get all the way to the Windows logo if I do a cold boot. No matter what, it always hangs. Sometimes even during the POST. I am totally stumped. What could be causing this? Any help would be much appreciated.
How did you test them, just if you could grab date from it or did you run a disk scan to check for bad sectors?
I had a similar problem and it was bad sectors on my hard drive.
(BTW: LMAO at your sig :p)
I ran a scan disk on them and nothing came out. I might try running some more tests on it though, cause seems like it could be the problem.
idk if this will work in XP, but if you can, try getting to a console (the "DOS" screen, i.e. C:\)
type:
scanreg /fix
what that does (at least in 98) is it rebuilds the registry and fixes stuff in it, if this works in XP, then it might solve some problems; if not, see if the recovery console works. if not, try reformatting :(
At least you can backup your info to other compy's...sry man.
gl
type:
scanreg /fix
gl
Yeah try the scanreg command and also "chdsk" (I think that is it), that fixed my problem that was similar.
Just be thankful you can get the data off of it, some arn't as lucky...
Thanks, I will do this tonight. I just tried a different hard drive in there, but had the same problem. Hopefully this will work, or I'll have no idea whats wrong with it. :(
is your pci bus locked? make sure...
run memtest recently? try it...
If its going into windows and then crashing, I would say probaly a HD problem.
this might sound odd but why dont you try putting in a windows XP pro install disk and maybe try doing a REPAIR install?
This may be stupid but, recently i helped some guy out who had a similar problem, would only load so much and than do nothing. So after an hour of checking everything and doing everything possible i could think off software wise, i opened his box up and looked inside. well 40 minutes later i look at his heat sink and only god knows how but it had actully come off and lifted off the die which was makeing it over heat almost instantly. After re seating it worked perfectly. This is probably not even close to be your case but something to think about.
