Computer maybe dead!
TheBear
My computer has somehow messed up and i am not sure what it is. Today my bro was playing warcraft 3 and the screen just went grey and then the computer shutdown.
However it worked later on. Then i was playing a game and after awhile the colors got all distorted and then it went grey and shut down.
I thought my video card burned up. However i tried my other card, the 8500le and that did not work either on the computer.
Right now whenever i start the computer up there is this one long beep and the computer never starts up. Could the agp slot burned out or is my hard drive or cpu messed up?
Please help!
Abit NF7-s
AMd xp2500
Corsair xms 3200
Ati radeon 9700pro
Western digital 180 gb hard drive
Antec case with antec smart fan and antec 350 watt power supply
Sounds like a fried CPU to me. Try taking it out and looking for burns, and if there are none, reseat it.
Check cooling fans, if it shuts down and comes back later it's often overheating. Also, check the voltages your powersupply provides, might have problems there (the ps sounds like an oem product).
Would be antec if it came with the case like most antec psu's do.
Ram or cpu would be my guess. Whats your rails look like ?
yep, it's an antec. An Antec $15 supply probably if it's a 350 W. Got the same with an enermax case; a lot of the brand name case and PS makers have a "less pricy" line they put into their cases.
There is also the easy test - take out the cpu, ram and video card one by one and boot, and check if the beep code changes.
