I had a running, fully functional computer when I accidentally pulled the power cord out from the PSU when I was untangling wires.
I plugged it back in, at which point the fans/lights all powered up (I didn't hit the power utton at this point, it just went on by itself), but there was no post. I held the power button down to shut it off, then turned it back on - the fans/lights all came on (including the loud graphics card fan at 100%), except the 200mm fan on top which seemed like it was struggling to move (movingly slightly back and forth).
So I turned it off and left it alone for a few minutes, then tried to turn the power on again. All lights/fans came on, including the 200mm fan for about 6 sceonds. Then the whole thing shut down for about 3 seconds, and then came back on again on its own and stayed on until I turned it off.
Since then, when I turn it on it either does the 6 seconds on, 3 seconds off, back on indefintiely thing, or it comes on and stays on the first time
When it does this there's no post beep or any sort of noise except the fans and I think the hard drives spin up but I'm not positive. The monitors won't even click out of standby mode.
Hardware is:
Corsair 520hx psu, antec 900 case, DFI tr2s dark (p35) motherboard, 8800 GTS video, 2x2gb ram, core 2 duo.
I have a spare computer, but it was built in 2004 so it's hard to swap hardware to test it out. I can't plug the old power supply into the new system because it doesn't have PCI-e power pins... I can't substitute the old card because it's AGP... and I don't have any PCI video cards sitting around.
Is it likely my PSU is fried? How would I go about testing that? If not, what component is likely giving me the problem? What steps should I take to isolate the problem or potentially fix it? Any ideas? Thanks.
Hardware is:
