Computer keeps restarting help plz.
FLAWLESS
Ok I turned my computer on this morning. As soon as i did, It loaded perfectly to the windows load up screen. When it reached the window load up screen, it took a long time till for it to go to next step which would be the start of windows. The computer than restarts on the window load up screen and loads up again till it stops at the safe mode page, it gives me the options to run safe mode, safe mode with networking, run last time the computer ran good, safe mode command prompt, and finally Normal. The only ones that would work and take me pass the window screen was safe mode, networking and command prompt one. I try shutting it down propertly from safe mode, but it does the same thing it did when i 1st started the computer. which was restart. any ideas?
80-90% of problems on a socket A system can be attributed to:
PSU
Heat
Memory/Hardware incompatibilty
Bad mainboard components (ie bad capacitors)
How about listing everything about your system here. Also check the mainboard for failed caps.
friend did install a 56k modem but that was a while back again liek a week or so. other than that its been the same system for about 2 years, you think if i reformat it would fix it?
