Computer Issues (Slow downs freezes) Vista 32bit
KBB
Hi,
I would like to get some opinions on an issue I am having with my PC.
(Sys. Specs and HijackThis log at bottom of post)
I have just recently (right around Jan, 2nd or so) started having some issues with my PC that I have been unable to sort out.
My PC will run fine for a while, about 8 hours this time under a heavy load pretty much the entire time. I was alternating between 3dsMax, Photoshop, Illustrator, NWN2 Toolkit and NWN2 pretty much the entire time, it finally froze while I had NWN 2 running (I had been playing it about 2 hours)
After that happens I will have peformance problems,the PC will become very un-responsive.
For example, task manager takes a long time to open, sometimes more than 30secs. Most other programs take allot longer than normal to open as well. And shutting down the PC in this state takes forever or I have to force it by holding in the power button for 4secs.
I have not really found any errors in Event Manager and usually the programs only freeze and I have to manually kill the app. Although Desktop Manager (dmw.exe) has been crashing occasionally since this started.
At first I suspected, Virus/spyware or software conflicts.
I checked my system with AVG, Bit Defender, Spybot, Super Anti Spyware and Hijack This. I found only a few tracking cookies but the scans did not detect any viruses or spyware. From what I could tell HJT looked okay.
I had installed Cubase 4, some drivers for a few usb recording/mixing devices and some new sound card drivers right before this started, but have since removed all of that for now and reverted back to an older sound card driver I was using before this problem. (I use Revo-Uninstaller to remove programs and their registry entries as well as Driver Sweeper)
So now I’m thinking Hardware, maybe RAM?
I have run a Mem Tester from a bootable CD but it reported no errors on the first test, going to run it again here in a few mins. Only did a short run for a few hours the first time,
I have noticed a crazy amount of Hard Faults, like just now when I opened Firefox, one of the AVG services spiked to over 1200 Hard Faults, also Explorer.exe hit about 400 I think. But it goes back down after the App loads. I’m show 2 right now in WINWORD.exe (I’m using MS Word to type this) and 0 all other apps/services others, This is happening while I have like 70% free memory left.
I have 4gb of ram and don’t really ever remember seeing many (or even any really) Hard Faults at all on this system, but I don’t check it all the time either.
I would really appreciate any advice, right now I'm going to run the mem-tester again and after that try swapping out memory sticks, I have 4x 1gb sticks installed.
Just let me know if more info is needed I'll try to get it up here as soon as I can.
Thanks for reading, sorry about the length..
SYSTEM INFO:
Windows Vista HP 32 bit SP1
Core 2 Quad Q6600 G0-stepping @Stock speed
Asus Striker Extreme 680i BIOS 1603
4x 1gb Modules Patriot Extreme EPP DDR2 6400
eVGA Geforce 280 GTX drv.180.48
SB Audigy 2 ZS
PC-P&C Silencer QUAD 750watt
Hijack This Log (Posted this since I may have missed something)
Code:
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 8:30:46 PM, on 1/8/2009
Platform: Windows Vista SP1 (WinNT 6.00.1905)
MSIE: Internet Explorer v7.00 (7.00.6001.18000)
Boot mode: Normal
Running processes:
C:\Windows\system32\taskeng.exe
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Program Files\Windows Defender\MSASCui.exe
C:\Program Files\Razer\Lachesis\razerhid.exe
C:\Program Files\Razer\Lachesis\OSD.exe
C:\Windows\System32\rundll32.exe
C:\Windows\System32\CTHELPER.EXE
C:\Windows\ehome\ehtray.exe
C:\Windows\ehome\ehmsas.exe
C:\Program Files\Windows Media Player\wmpnscfg.exe
C:\Windows\system32\wbem\unsecapp.exe
C:\Program Files\Razer\Lachesis\razerofa.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL
O3 - Toolbar: AVG Security Toolbar - {A057A204-BACC-4D26-9990-79A187E2698E} - C:\PROGRA~1\AVG\AVG8\AVGTOO~1.DLL
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKLM\..\Run: [Launch LGDCore] "C:\Program Files\Common Files\Logitech\G-series Software\LGDCore.exe" /SHOWHIDE
O4 - HKLM\..\Run: [Launch LCDMon] "C:\Program Files\Common Files\Logitech\LCD Manager\lcdmon.exe"
O4 - HKLM\..\Run: [Lachesis] C:\Program Files\Razer\Lachesis\razerhid.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Nero\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [NBKeyScan] "C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe"
O4 - HKLM\..\Run: [EVGAPrecision] "C:\Program Files\EVGA Precision\EVGAPrecisionWrapper.exe" /s
O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [CTxfiHlp] CTXFIHLP.EXE
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [NVIDIA nTune] "E:\Vista Gaming Program Files\nTune\nTuneCmd.exe" clear
O4 - HKCU\..\Run: [igndlm.exe] C:\Program Files\Download Manager\dlm.exe /windowsstart /startifwork
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [DevconDefaultDB] C:\Windows\system32\READREG /SILENT /FAIL=1 (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [DevconDefaultDB] C:\Windows\system32\READREG /SILENT /FAIL=1 (User 'Default user')
O4 - Startup: OneNote 2007 Screen Clipper and Launcher.lnk = D:\Microsoft\MS Office 2007\Office12\ONENOTEM.EXE
O8 - Extra context menu item: &ieSpell Options - res://C:\Program Files\ieSpell\iespell.dll/SPELLOPTION.HTM
O8 - Extra context menu item: Check &Spelling - res://C:\Program Files\ieSpell\iespell.dll/SPELLCHECK.HTM
O8 - Extra context menu item: E&xport to Microsoft Excel - res://D:\MICROS~1\MSOFFI~1\Office12\EXCEL.EXE/3000
O8 - Extra context menu item: Lookup on Merriam Webster - file://C:\Program Files\ieSpell\Merriam Webster.HTM
O8 - Extra context menu item: Lookup on Wikipedia - file://C:\Program Files\ieSpell\wikipedia.HTM
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_05\bin\ssv.dll
O9 - Extra button: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra 'Tools' menuitem: ieSpell - {0E17D5B7-9F5D-4fee-9DF6-CA6EE38B68A8} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra button: (no name) - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra 'Tools' menuitem: ieSpell Options - {1606D6F9-9D3B-4aea-A025-ED5B2FD488E7} - C:\Program Files\ieSpell\iespell.dll
O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - D:\MICROS~1\MSOFFI~1\Office12\REFIEBAR.DLL
O16 - DPF: {48DD0448-9209-4F81-9F6D-D83562940134} -
O16 - DPF: {67A5F8DC-1A4B-4D66-9F24-A704AD929EEE} -
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O20 - AppInit_DLLs: avgrsstx.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: AVG8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: ##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762## (Bonjour Service) - Apple Computer, Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: mental ray 3.6 Satellite for Autodesk 3ds Max 2008 32-bit 32-bit (mi-raysat_3dsMax2008_32) - Unknown owner - E:\Vista Gaming Program Files\Autodesk\3ds Max 2008\mentalray\satellite\raysat_3dsMax2008_32server.exe (file missing)
O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\Windows\system32\nvvsvc.exe
O23 - Service: PnkBstrA - Unknown owner - C:\Windows\system32\PnkBstrA.exe
O23 - Service: PnkBstrB - Unknown owner - C:\Windows\system32\PnkBstrB.exe
O23 - Service: Rsv2gput - QLogic Corporation - C:\Windows\system32\drivers\ql40xx.sys
O23 - Service: SBSD Security Center Service (SBSDWSCService) - Safer Networking Ltd. - C:\Program Files\Spybot - Search & Destroy\SDWinSec.exe
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files\Common Files\Steam\SteamService.exe
End of file - 8140 bytes
UPDATE:
Just wanted to add that all temps and voltages are running at normal levels,
I do have to set the fan on my graphics card (280gtx) to manual @ 100% rpm when running games, or the card can get over 70o C with the fan on max it stays around 63-65o C, but these cards are known to run pretty hot with air cooling.
Update:
12 Hours of mem test did the extended version and ran it through 3 times no errors :p
