As of late I have been experiencing a lot of issues w/ my pc. First the specs..
80gb wd special edition
geforce 4 ti
athlon 2000+
gigabyte 7vrxp
corsair xms 256mb 3200(?)
tdk 16x burner
8x dvd rom
i haven't had the chance to find the po for my computer, but that is what i recall.
here is what happens..
doing normal computing (browsing, music, etc.) doesn't cause any problems. When playing a video game, i will either BSOD, game with crash, or video will lock up. BSOD happens the most often. i get the following errors with the BSOD:
DRIVER_IRQ_NOT_LESS_OR_EQUAL
nv4_disp.dll
just a memory address.
i got an iPod for xmas. i have importing a lot of my cds through iTunes. I get an error while importing (along the lines of read error). Sometimes i get a BSOD. using other ripping utils cause the problem.
i think the problems are related. i check my temp, it seemed a little high so i opened the case, and put it in the center of the room instead of under my desk. however, i still get the BSOD. i checked my voltages, and they are as follows
-12 is at -7
-5 is at 0.
3.3 is at 3.23
5.0 is at 4.99
12 is at 12.50
obviously this isn't good. could the bad voltages be causing a problem? what kind of problems are associated with bad voltages??
geforce 4 ti
athlon 2000+
gigabyte 7vrxp
tdk 16x burner
8x dvd rom
nv4_disp.dll
-12 is at -7
-5 is at 0.
3.3 is at 3.23
5.0 is at 4.99
12 is at 12.50
